2950 Failed Redundant power supply
Answered Question
I have a particular 2950 12 switch that the Cisco Network Assistant shows as having a failed redundant power supply error. I pulled the switch from the rack and there is only a single power supply in it and it is functioning. Can I just acknowledge this warning and carry on, or should I be concerned about possible future power supply failure?
Neil
Correct Answer by sundar.palaniappan about 9 years 7 months ago
Do a 'show env all' if the PS status shows failed then you would have to replace it.
Sundar
Overall Rating: 5 (1 ratings)
Correct Answer
sundar.palaniappan Tue, 07/17/2007 - 13:24
Sundar
tbhagia Wed, 07/18/2007 - 22:20
Hi Neil,
I would suggest you to visually inspect the switch. The switch has 6 LEDs on the front panel for management purpose.
RPS LED:
- off: RPS is off or is not installed.
- Flashing amber: The internal power supply in a switch has failed, and the RPS is providing power to the switch (redundancy has been allocated to this device).
reference: http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/hardware/installation/guide/hgovrev.html#wp1022295
CLI command:
show env power
the above command will provide you information about the power supply
Hope this helps!
