Question about module compatibility
Jul 17th, 2007
Is the WS-X6548-GE-TX module compatible with a Supervisor2 engine with a Switch Fabric Module installed? Should I be able to hot swap the new module in? What does "Fabric enabled" mean int he product literature? Are there extra connections/cables involved or just slide it on in?
Overall Rating: 3 (1 ratings)
mohammedmahmoud Tue, 07/17/2007 - 13:36
Yes it is, the "Fabric enabled" means that it can utilize the Switch Fabric Module installed, and yes it supports OIR (hot swap).
Mohammed Mahmoud.
Christopher007 Tue, 07/17/2007 - 14:35
Thanks for replying! Do I need to do anything special with the SFM, because when I try to insert the new WS-X6548-GE-TX module, a bunch of alarms go off on the front panel interface of the SFM as well as log messages that say switch module timed out.
