Need help clearing vlans
Answered Question
I have a C2924 and need to remove the vlans and leave the defualt ones only.
Correct Answer by jay77jay77 about 9 years 7 months ago
u may try: "del vlan.dat"
Cheers!
Correct Answer by smothuku about 9 years 7 months ago
Hi Javier ,
You mean you want only vlan 1 in your switch...
what is the meaning of "need to remove the vlans and leave the defualt ones only" ..
You can erase start up config and reload the switch if you want vlan 1 in your switch...
you can use the following coomand to delete a vlan from database....
no vlan
cheers :)
satish
Overall Rating: 5 (2 ratings)
Correct Answer
smothuku Tue, 07/17/2007 - 21:23
Hi Javier ,
no vlan
cheers :)
satish
