07-18-2007 01:01 AM
How can I know when a Gatekeeper send an resolution failure to gateway.
thanks
07-18-2007 12:52 PM
You can use the following commands on the gatekeeper:
term mon
debug h225 asn1
debug gatekeeper main 10
These will show you the messages sent between the gateway and gatekeeper as well as the gatekeeper logic for accepting or rejecting the call. Be sure to do "undebug all" when you're finished.
Hope this helps. If so, please rate the post.
Brandon
07-19-2007 10:05 AM
Hi Brandon,
I'm thinking in management not in troubleshooting. I already search for SNMP counter or show command (the 'sh gatek perform stat' doesn't show the address lookup failure). The gtk has more or less 6000 prefix and alot of activity, and for this reason it's impossible to look for debugs.
Thanks anyway.
regards
