Syslog from Cat 4003/4006 CatOS
Jul 18th, 2007
Hi All
I have configured snmp properties from Cat 4003/4006. Changed the public string and configured ip permit list for snmp to the Ciscoworks Servers.
I cannot get any syslog messages on the boxes or in the Ciscoworks syslogs.
Please help.
Pavel Bykov Wed, 07/18/2007 - 05:01
  • Silver, 250 points or more
For Syslog and SNMP are different things.
For syslog:
set system syslog-file
set logging server enable
set logging server x.x.x.x
set logging server severity 6
Alternatively, you can specify file where to write syslog on your flash memory with "set system syslog-file" command. Without any parameter it sets syslog to default file. 4003/6 is old stuff, maybe you have to specify it there.
londint Wed, 07/18/2007 - 23:59
Sorry, my mistake. Thanks Guys
I meant syslog
I have the following (in the attached file) on the Switches and the .xls in the Ciscowork but I still do not receive any messages from the Cat 4003 and 4006. Please help.
Ok serveral things to look at:
on the switches you should have something near this in the configuration (this is from 7-6-9.bin)
set logging console enable
set logging telnet enable
set logging server (ip address of your ciscoworks box)
set logging level cdp 4 default
set logging level mcast 4 default
set logging level dtp 4 default
set logging level dvlan 4 default
set logging level earl 4 default
set logging level ip 4 default
set logging level pruning 4 default
set logging level snmp 4 default
set logging level spantree 4 default
set logging level sys 4 default
set logging level tac 4 default
set logging level tcp 4 default
set logging level telnet 4 default
set logging level tftp 4 default
set logging level vtp 4 default
set logging level vmps 4 default
set logging level kernel 4 default
set logging level filesys 4 default
set logging level mgmt 4 default
set logging level mls 4 default
set logging level protfilt 4 default
set logging level security 4 default
set logging level radius 4 default
set logging level udld 4 default
set logging level gvrp 4 default
set logging level cops 4 default
set logging level qos 4 default
set logging level acl 4 default
set logging level rsvp 4 default
set logging level ld 4 default
set logging level privatevlan 4 default
set logging level ethc 5 default
set logging level gl2pt 4 default
set logging server facility LOCAL7
set logging timestamp enable
set logging buffer 500
On your ciscoworks server:
1. Are both of your devices in the inventory ?
2. When you run an "unexpected device" report in RME does an ip address associated with either of those devices show up ?
