1721 ATM dialer backup for serial line
Jul 18th, 2007
Hi all,
I've been using the following config for ADSL backup to a serial line, however it seems to show strange behaviour.
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
description Customer LAN
ip address 1.1.1.1 255.255.255.248
speed auto
interface Serial0
description Link to ISP
bandwidth 1024
backup interface Dialer1
ip address 2.2.2.2 255.255.255.252
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
ppp chap hostname [email protected]
ppp chap password 0 1234
ppp pap sent-username [email protected] password 0 1234
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Dialer1 254
When the router boots up with both lines connected, the Dialer1 is set to standby state, whilst the serial is working. If the serial line drops, logging shows the Dialer1 go up, but no further authentication/PPP events are logged and the device doesn't log in.
IF the router is booted up with the serial line disconnected, the ATM interface and dialer interface are brought up and the DSL works, and when the serial line is then brought up/dropped the ATM/Dialer will work each time.
Can anyone advise why this would be the case, or what better way to do the configuration.
We have swapped to using:
interface serial0
backup interface ATM0
So that the whole adsl is disabled until required, however this stops us from checking on ADSL sync/monitoring.
Thanks in advance!
purohit_810 Wed, 07/18/2007 - 05:23
  • Silver, 250 points or more
You has to put...
int dialer1
ppp authentication chap (Should both end same)
idle time-out
router(Conf)#dialer-list 1 protocol ip permit
** Without this DDR will not work **
ip route 0.0.0.0 0.0.0.0 Dialer1 150
andybonyx Wed, 07/18/2007 - 06:21
Thanks for that, sorry I should have mentioned that I had the dialer-list statement.
I have tried adding the ppp authentication and I have the same problem. Here is a log of the config and debug output.
When I manually issue an ATM0 clear, it brings the DSL up
interface ATM0
no ip address
no ip mroute-cache
hold-queue 224 in
pvc 0/38
speed auto
interface Serial0
bandwidth 1024
interface Dialer1
encapsulation ppp
dialer pool 1
ip classless
no ip http server
00:01:48: %LINK-3-UPDOWN: Interface Serial0, changed state to down
00:01:48: BACKUP(Serial0): event = primary interface went down
00:01:48: BACKUP(Serial0): changed state to "waiting to backup"
00:01:48: BACKUP(Serial0): event = timer expired on primary
00:01:48: BACKUP(Serial0): secondary interface (Dialer1) made active
00:01:48: BACKUP(Serial0): changed state to "backup mode"
00:01:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
00:01:49: BACKUP(Serial0): event = primary interface went down
00:01:50: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
00:01:50: BACKUP(Dialer1): event = secondary interface came up
00:01:51: BACKUP(Dialer1): event = secondary interface came up
00:02:21: BACKUP(Serial0): event = primary interface went down
router#ping 64.233.183.103
Sending 5, 100-byte ICMP Echos to 64.233.183.103, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router#
router#
router#clear int atm0
router#
00:02:47: ATM0 dslsar_1a_reset: PLIM type is 18, Rate is 288Mbps
00:02:47: ATM0 dslsar_1a_shutdown: state=4
00:02:47: dslsar disable ATM0
00:02:47: Resetting ATM0
00:02:47: dslsar_1a_teardown_vc(ATM0): vc:1 vpi:0 vci:38
00:02:47: dslsar_1a_config(ATM0)
00:02:47: dslsar_1a_enable(ATM0)
00:02:47: ATM0: dslsar_init
00:02:47: ATM0 dslsar_MatchSARTxToLineSpeed(): usbw 288, clkPerCell 52013 prev_clkPerCell 9702
00:02:47: ATM0 dslsar_MatchSARTxToLineSpeed(): Changing line speed from fast to slow
00:02:47: ATM0 dslsar_update_us_bandwidth(): upstream bw =288 Kbps
00:02:48: (ATM0)1a_enable: delay activation of vcd=1, vc=0x82C4CFBC
00:02:48: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
00:02:49: dslsar enable ATM0
00:02:49: ATM0: dslsar_bringup_interface: Interface and atm_db flags are UP
00:02:50: dslsar_txRingParamInit_and_tcqSetup(): default tx-ring setting is selected for vpi/vci = 0/38
00:02:50: ATM0:dslsar_init_tx_chan_desc_per_vc, vcd = 1, addr = 0x00011040, size = 64
00:02:50: ATM0 dslsar_vc_setup: vcd 1
00:02:50: CONFIGURING(ATM0) VC 1 (0/38) IN TX SCHEDULE TABLE SET 0
00:02:50: (ATM0)Forcing Peakrate and Avgrate to: 288
00:02:50: (ATM0)Requested QoS: Peakrate = 288, Avgrate = 288, Burstsize =0
00:02:50: (ATM0)Configuring VC 1: slot 0 in TST 5
00:02:50: (ATM0) SUCCESSFUL CONFIGURATION OF VC 1 (0/38), QOS Type 4
00:02:50: dslsar_setup_cos(ATM0): vc:1 wred_name:- max_q:0
00:02:50: ATM0: vcd = 1, max_tx_time = 7450
00:06:47: Vi2 PPP: No authorization without authentication
00:06:47: Vi2 CHAP: I CHALLENGE id 212 len 35 from "ERX3.Sheffield"
00:06:47: Vi2 CHAP: Using hostname from interface CHAP
00:06:47: Vi2 CHAP: Using password from interface CHAP
00:06:47: Vi2 CHAP: O RESPONSE id 212 len 48 from "[email protected]"
00:06:51: Vi2 CHAP: I SUCCESS id 212 len 4
00:06:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
