DFM 2.0 Install Error!!
Jul 18th, 2007
Hi to all!
I've installed LMS 2.5.1 upgrade bundle on solaris 8.
After DFM installation, the finish give me this error:
Finished: Wed Jul 18 15:35:35 MEST 2007
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
WARNING: Exiting installation beyond this point might result in system instability.
WARNING: Please run the program <NMSROOT>/bin/dfmValidateUpgrade.sh
WARNING: to validate that this is an upgrade.
ERROR: Cannot open internal files (cmd must be run by superuser). (OVs 1-12)
I don't have any OV application in my environment, but I've two directory named /opt/OV/lib and /opt/OV/bin needed to use some snmp command.
Any ideas?
TKS
Leonardo
David Stanford Wed, 07/18/2007 - 06:37
  • Cisco Employee,
Are you installing the upgrade version as root or sudo?
Leonardo Roberto Wed, 07/18/2007 - 06:50
as a root.
you know I've installed now the LMS2.6 upgrade tool. this the error that I've cached:
Installing DFM
ORIG_LRF /opt/CSCOpx/objects/smarts/conf/OV/sm_ovfwd.orig
NEW_LRF /opt/CSCOpx/objects/smarts/conf/OV/sm_ovfwd.lrf
cp: cannot access /opt/CSCOpx/objects/smarts/conf/OV/sm_ovfwd.orig
INFO: HP-OpenView is installed.
Installing HP-OV adapter.
ovstop: ovspmd is not running
ovaddobj - Static Registration Utility
Adapter registration failed.
This is not a fatal error if you are installing it on a
non-HP-OpenView collection or management station. For the
collection or management station installation please
execute the following command:
ovaddobj /opt/CSCOpx/objects/smarts/conf/OV/sm_ovfwd.lrf
ovstart: unable to start ovspmd
seems that DFM installation, search the OV adapter.
My installation was without HPOV adapter.
I think the existance of OV dir and some bin command under this path had confuse DFM instllation.
any idea about the integrity of DFM installation?
