CISCOWorks & Internet Explorer 7
Jul 18th, 2007
I am having problems with CISCOWorks LMS 2.6. I could access it with IE 6 but not with Internet Explorer 7. It says 'cannnot connect to ANI server: ANIServer5.0.3-Orion. Verify that ANIServer5.0.3-Orion is running and restart campus manager'. It works fine from the server with Internet Explorer 6. Is this a normal problem? Is there any way to solve it? . Thank you.
Overall Rating: 5 (1 ratings)
David Stanford Wed, 07/18/2007 - 06:36
LMS 2.6 is not supported with IE 7. Also, check to make sure you are running a supported Java plugin version.
IE 7 support is added to LMS 3.0
Ferdiazpo Thu, 07/19/2007 - 03:40
At the end it was not working also with IE 6. The version of the java plugin was fine. The file ani.log showed that a CORBA object was not found when I was trying to access.
I saw that the server was using 3 GB of memory with only 2GB of physical memory. Restarting the server solved the problem and now topology services work both with IE 6.0 & 7.0. But memory didn't improve too much, only to 2.6 GB.
