bgp announce /24
Answered Question
Jul 18th, 2007
hi
we re-config the bgp and we would like to have as following:
for provider A
200.1.0.0/24
200.1.1.0/24
200.1.2.0/23
for provider B
200.1.0.0/24
200.1.1.0/24
200.1.2.0/24
200.1.3.0/24
we find that the router always announces /23 to provider B. How do we send four routes? pls advice
router bgp 30x
network 200.1.0.0
network 200.1.1.0
network 200.1.2.0 mask 255.255.254.0
neighbor 202.1.1.1 route-map Set_ASN_PB out
ip route 200.1.2.0 mask 255.255.254.0 null0 250
access-list 20 permit 200.1.0.0 0.0.0.255
access-list 20 permit 200.1.1.0 0.0.0.255
access-list 20 permit 200.1.2.0 0.0.0.255
access-list 20 permit 200.1.3.0 0.0.0.255
ip as-path access-list 130 deny .*
ip as-path access-list 130 permit ^$
route-map Set_ASN_PB permit 10
match ip address 20
route-map Set_ASN_PB permit 30
match as-path 130
BGP table version is 248, local router ID is 10.254.210.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 200.1.0.0 0.0.0.0 0 32768 i
*> 200.1.1.0 0.0.0.0 0 32768 i
*> 200.1.2.0/23 0.0.0.0 0 32768 i
Correct Answer by Pavel Bykov about 9 years 8 months ago
If you want to advertise all four routes, do a:
router bgp 30x
network 200.1.0.0
network 200.1.1.0
no network 200.1.2.0 mask 255.255.254.0
network 200.1.2.0
network 200.1.3.0
aggregate-address 200.1.2.0 mask 255.255.254.0
neighbor providerA route-map Set_ASN_PA out
neighbor providerB route-map Set_ASN_PB out
ip prefix-list ProviderA seq 10 permit 200.1.0.0/23 ge 24
ip prefix-list ProviderA seq 20 permit 200.1.2.0/23
ip prefix-list ProviderB seq 10 permit 200.1.0.0/22 ge 24
route-map Set_ASN_PA permit 10
match ip address prefix-list ProviderA
route-map Set_ASN_PA permit 30
match as-path 130
match ip address prefix-list ProviderB
match as-path 130
This way, in routing table you will have /24 and /23 routes, but route-map will advertise only /24 to provider B, and /24 and /23 to provider A.
Overall Rating: 5 (4 ratings)
purohit_810 Wed, 07/18/2007 - 06:23
  • Silver, 250 points or more
You should use 200.1.0.0/22 Use.
It will conver your subnets
200.1.0.0/24
200.1.1.0/24
200.1.2.0/24
200.1.3.0/24
For 200.1.2.0/23, Advertise separately also. Because it covers more hosts than 200.1.2.0/24.
Or You can advertise that by Concept " periodic downloaded static route ".
Above routing table is true according to route aggregation.
Dharmesh Purohit
Correct Answer
Pavel Bykov Wed, 07/18/2007 - 07:28
router bgp 30x
network 200.1.0.0
network 200.1.1.0
network 200.1.2.0
network 200.1.3.0
match as-path 130
match as-path 130
