Difference between WS-X6K-SUP2-2GE and WS-X6K-S2U-MSFC2 sup model
Jul 18th, 2007
need help,
can anybody tell me the diffrence between and WS-X6K-SUP2-2GE and WS-X6K-S2U-MSFC2 sup model and can i use both the model in cisco 6509 switch in RPR+ mode(Redundancy)using native OS.
Akash
Overall Rating: 5 (2 ratings)
ccnp_ccie Wed, 07/18/2007 - 07:36
thanks for reply,
i have same ios on both the sup card, can i used both of them same time on cisco 6509 switch using RPR+.
thanks & Regards
Akash
Edison Ortiz Wed, 07/18/2007 - 07:29
  • Hall of Fame,
    Founding Member
You sure can, both Supe Models are the same. The part number is different because one was built before 2001. The post-2001 model contains 256MB DRAM on the Supe and 256MB DRAM on the MSFC
http://www.cisco.com/warp/public/473/151.html#topic3
[edit]
Found another link where it states the default memory has changed to 512MB on MSFC
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd8017a5e7.html
HTH,
