Problem with SelectPrivateKey
smeyer000
I am having problems logging in to my VPN connection that I just upgraded from 4.6 to 4.8. The install seemed fine and new key Verifies successfully, but I get the following error when it tries to load the key for the certificate.
Any help would be apprectiated.
21:14:24.781 07/15/07 Sev=Info/4 CERT/0x6360001E
Function C_SelectPrivateKeyBySPKI failed with an error code - 0x000007A3
a-vazquez
Level 6
Level 6
I think you may have to load the certificate to check the revocation list optionally with the command:
ca configure chpca01.corp.chpinfo.com ra 1 0 crloptional. You may also have to remove the Send CA certificate chain option check mark on the client and enable isakmp identity hostname instead of isakmp identity address.
