BAT Export device list, DID, etc CCM 4.2 to 5.1
Jul 18th, 2007
Im doing a fresh install of 5.1 and not migrating from 4.2 to 5.1. We want to export the phones from 4.2 with the MACs, DID, display names, etc. Can I do this with BAT?
Overall Rating: 5 (1 ratings)
jbarcena Wed, 07/18/2007 - 12:46
It is not supported and most of the times it does not work. You need to import using the same BAT version as well as the same CCM version as the one that was used for the export, eventhough I have seen it to work using different versions but once again most of the times does not work.
Tommer Catlin Wed, 07/18/2007 - 13:03
Hi Jorge -
Correct me if I am wrong, if I can get the MACs, phone type and DNs out of the 4.2 into the CSV file. Then I can copy those out the 5.1 BAT tool excel and create a new CSV Bat.
Thanks for your help!
rob.huffman Wed, 07/18/2007 - 13:19
Hey Tommer,
I don't see why your method of applying the the proper Export Fields from the 4.2 CSV to the applicable Fields in the 5.1 BAT.xlt or CSV wouldn't work :) The problem here is that the Fields from one version of BAT don't always match up with the newer version of BAT. If you are willing to do the legwork I don't see why it would be a problem.
Take care!
Tommer Catlin Wed, 07/18/2007 - 13:22
Thanks Rob. I was thinking of just copying pasting the 4.2 phones and info I need out to the new BAT excel worksheet, create a new CSV and import to 5.1. Im creating all new CSS, PTs, regions, etc. So a whole new green install is what we are going for, but re-using the MACs, DNs, display txt, etc.
metalium2007 Wed, 07/18/2007 - 13:37
Its the best way. I've done it in a migration from 3.3.2 to 5.1. It's not so much work as you can think. It worths!
Good luck
