Cisco ASA 5510 issue
Jul 18th, 2007
I have Cisco ASA 5510 ,which 4 interface and one management interface
Please go through the following interface configuration and nat and access-list,then i have a PC connected a PC in the dmz switch whose IP add is 172.16.1.100 /24
And I have another PC connected to inside zone whose Ip add is 192.168.100.100 which is natted to 172.16.2.1 for DMZ to Inside communication.
Now the issue is I am not able to ping(172.16.2.20) the PC (private IP is 192.168.100.100 natted IP 172.16.2.20)from the dmz zone PC (from 172.16.1.100)
Please help me to resolve the issue.
configuration details:
interface Ethernet0/0
nameif outside
speed 100
duplex full
security−level 0
ip address 10.20.158.32 255.255.0.0
no shut
interface Ethernet0/1
nameif inside
security−level 100
speed 100
duplex full
ip address 192.168.100.1 255.255.255.0
no shut
interface Ethernet0/2
nameif dmz
security−level 50
speed 100
duplex full
ip address 172.16.1.2 255.255.255.0
no shut
route Outside 0.0.0.0 0.0.0.0 10.20.0.1
nat (inside) 1 192.168.100.0 255.255.255.0 0 0
global (outside) 1 interface
static (inside,DMZ) 172.16.2.20 192.168.100.100
netmask 255.255.255.255
access−list DMZtoInside extended permit ip host 172.16.1.100 host 172.16.2.20
access−group DMZtoInside in interface DMZ
Then trouble shooting by issuing clear xlate,then try pinging... but not pinging,from the ASA propmt I able to ping both inside interface IP and dmz interface IP,and both zone PCs,but not able to ping between PCS.
Thanks and Regards,
S.Venkataraman
acomiskey Wed, 07/18/2007 - 10:19
You must allow icmp in your acl.
access−list DMZtoInside extended permit icmp host 172.16.1.100 host 172.16.2.20
Please rate helpful posts.
