Pix501 StoS Can only Ping
Jul 18th, 2007
I have just set up a Pix 501 site to site VPN using the VPN wizard. I can ping the clients on the other side but that is it. Nothing else seems to work. I want to set up RDP but I cannot figure out how to configure.
gmarogi Tue, 07/24/2007 - 13:21
configuration is used between two IPSec security gateways, which can include PIX Firewalls, VPN concentrators, or other devices that support site-to-site IPSec connectivity. When you select this option, a series of panels are displayed lets you enter the configuration required for this type of VPN. With a site-to-site VPN, your local PIX Firewall provides secure connectivity between your LAN and a LAN in a different geographic location
