H323 preference
Jul 18th, 2007
If the dialpeer have the same preference, this case is default 0. Does that mean the call will be distributed to the two ccms in round robin fashion, meaning one call to ccm1, the other call to ccm2? or the 2nd dial-peer will never used? or the call setup will send two servers sametime?Thanks
dial-peer voice 2 voip
destination-pattern 3385...
voice-class codec 1
session target ipv4:19.140.12.18
dtmf-relay h245-alphanumeric
dial-peer voice 3 voip
voice-class codec 1
session target ipv4:19.140.12.19
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 07/18/2007 - 12:35
  • Hall of Fame,
    Founding Member
Will be sent to the DP least recently used. In practice, round-robin.
jbarcena Wed, 07/18/2007 - 12:57
  • Red, 2250 points or more
The following factors determine the hunt order on a dial-peer:
1) Longest match
2) Preference
3) Random selection
So, if you have multiple dial peers with the same destination pattern and do not specify a preference, the dial peer match is random.
You can find that information in the Cisco Voice Gateways & Gatekeepers book.
//Jorge
