dyamic and static IPs allowed by single virtual-template
Jul 18th, 2007
I'm setting some PPPoA pvcs and I'd like to permit customers to configure their CPEs for either static or dynamic IP addresses. All the "customers" in this scenario are part of the same company with centralized IP mgmt, so there's no need to enforce IP allocation methods. Some sites will want static IPs and others won't need them. Here's my 7206VXR config:
interface Loopback101
ip address 10.180.1.254 255.255.255.255 end
interface ATM1/0.1396 point-to-point
pvc 1/396
encapsulation aal5mux ppp Virtual-Template2
interface Virtual-Template2
description test template
ip vrf forwarding TestCo
ip unnumbered Loopback101
no ip redirects
no ip unreachables
no logging event link-status
peer default ip address pool TestCo
end
ip local pool TestCo 10.180.1.1 10.180.1.20
Unfortunately when there's a pool configured in the template, an IP is assigned from the pool regardless of how the CPE is configured. In addition, all CPEs are Actiontec GT701s, which don't provide much debug info. Any ideas?
Chris
paolo bevilacqua Wed, 07/18/2007 - 17:23
  • Hall of Fame,
    Founding Member
what would be issue for you guys to just use another VT? It seems to me you are individually configuring each pvc anyway, as opposed to using ranges, for example.
reachonenetadm Tue, 07/24/2007 - 14:46
I had already defined a new template for this purpose. At first it seemed as if dynamic and static CPE configurations were mutually exclusive but, after letting it sit for a few days, it is working fine. I'm not sure what, if anything, had changed but it's working now. Thanks anyway..
Cheers
Chris
