switchport voice vlan
Jul 18th, 2007
Example:
interface fa0/1
switchport access vlan 10
switchport voice vlan 510
As far as I know, when we try this configuration your voice and vlan data are being carried on separate vlans. Also I have notice that when we perform a:
switch# show vlan
the swtichport shows up on both vlans (10 and 510). However, this normal behavior does not happen on a ws-c2924-xl switch. This switch model does have the commands available ("switchport voice vlan") but does not seem to put the port on both vlans. What I need the switch to do is tagged the voice traffic and leave data traffic untagged.
Am I wrong??
royalblues Wed, 07/18/2007 - 13:30
  • Green, 3000 points or more
Cisco negotiates a speciallized dot1q trunk when you use the voice vlan command and tags the voice vlan traffic and native vlan traffi as untagged
Since the XL series switches are pretty old, these might be shown on the trunk port
Narayan
Pavel Bykov Wed, 07/18/2007 - 14:17
  • Silver, 250 points or more
Also, IP phone might have to present for VLAN to be up on that switch. For some purposes Cisco uses CDPv2 to detect IP Phone
