Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928622members
1242302discussions
Community Activity
[Get One #24x7Support] How To Speak At Someone On Klm 𝗔irlines?
[Get One #24x7Support] How To Speak At Someone On Klm 헔irlines?퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with KLM 퐀퐢퐫퐥퐢퐧퐞퐬 +1-805-327-7444�, explore multiple ch헔nnels like their website, mobile 헔pp, or customer service +1-805-327-7444� hotline 헔t (UK line). Booking 헙헹헶헴헵혁s, m헔n헔gi...
how to speak directly at 𝗔𝗶𝗿 𝗖𝗮𝗻𝗮𝗱𝗮? {Help~line} #USA
Phone assistance: One of the quickest ways to speak with a 헔헶헿 헖헮헻헮헱헮 support agent is by calling +ퟭ:ퟴퟬퟱ::ퟯퟬퟵ::ퟵퟯퟳퟳ.// +ퟭ:ퟴퟬퟱ::ퟯퟬퟵ::ퟵퟯퟳퟳ. The phone number for 헔헶헿 헖헮헻헮헱헮 assistance is listed on their official website. Simply call the number and follo...
Resolved! Trying to drop certain logging messages with discriminator
There's two network monitoring accounts that constantly log in and out of my devices, and it's making it difficult to use logs to troubleshoot issues because the logs are totally clogged up with useless messages. I looked at the forums on how to drop...
is 𝗔𝗶𝗿 𝗖𝗮𝗻𝗮𝗱𝗮 24 7? [[Reach-Us]]
[Get One #24x7Support] How To Speak Directly At Klm 𝐀irlines?
[Get One #24x7Support] How To Speak Directly At Klm 퐀irlines?퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with KLM 퐀퐢퐫퐥퐢퐧퐞퐬 +1-805-327-7444�, explore multiple ch헔nnels like their website, mobile 헔pp, or customer service +1-805-327-7444� hotline 헔t (UK line). Booking 헙헹헶헴헵혁s, m헔n헔ging...
[Get One #24x7Support] How Do I Connect With People on KLM?
[Get One #24x7Support] How Do I Connect With People on KLM?퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with KLM 퐀퐢퐫퐥퐢퐧퐞퐬 +1-805-327-7444�, explore multiple ch헔nnels like their website, mobile 헔pp, or customer service +1-805-327-7444� hotline 헔t (UK line). Booking 헙헹헶헴헵혁s, m헔n헔ging r...
Azure SAML SSO Certificate Error, Firepower 1010
Hi, We are trying to implement Azure SAML SSO on our Firepower 1010. We are using ASA 9.19.1 and Secure client 5.0.02075. When we try the login via Azure by clicking the "Test this applicaton" the login works and there are no errors in the logs. The ...
8MFT-T1/E1
how to activate the module on cisco 4400 router for E1 connections.#card type e1 0 4 showing error, card not found or command wrong
Mitel - DHCP Discovery
Hi, I have a Mitel 5312 phone plugged into a switchport configured for ISE but when it boots up it gets stuck on DHCP Discovery. If I put the port to authentication open then it goes through and boots up as normal.The logs all look ok but I can't see...
Cisco Secure Client CVE-2024-20337
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 152 Views
  • 2 replies
Answer phone
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work. I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto an...
matee by Level 1
  • 319 Views
  • 12 replies
Intermittent Static noise on phones
We are a healthcare facility.  For past several months we have had several complaints from users that calls are often full of static.   We are running CUCM 12.5(1)SU8 and the phones are primarily 8811 running current firmware.   We have replaced phon...
