PEAP support with WDS
Jul 18th, 2007
I understand that the WDS can provide fast roaming by caching the authenticated user credentials when using LEAP. But what if I use PEAP with certificates for both server and client authentication? I suppose the WDS won't be able to cache the certificates. Then, how doesn't it work? Or is PEAP supported by WDS? Thanks.
Trending Topics - Security & Network
