MOH problem - New Audio Source File problem
Jul 18th, 2007
Dear folks,
I have a problem here with MOH. Currently, the version of CCM we are using is 4.1(3). We are using a new MOH audio source file which we uploaded 1 year ago. It was working fine.
However, when we try to change to a new MOH file recently, there are no error during uploading. And when we swing to the new MOH file, it is working fine for ard 1 week. But after that, when we put on hold, we do not hear anything from the MOH.
We try to swing back to the old one, its works perfectly well. A few weeks later, we swing to the new, its looks fine for a few days, afterwhich the same thing happen again.
Anyone can advise.
Its urgent.
Thanks alot.
Overall Rating: 4.5 (2 ratings)
Avner Izhar Fri, 08/17/2007 - 20:45
  • Bronze, 100 points or more
One or two servers? If two, have you uploaded the file to them both?
When the MOH stops with the new source, does the 'ip voice media streaming' runing?
This issue require logs tracking and would best be resolved using a TAC case.
HTH, Avner.
ONLYUNITED Mon, 08/27/2007 - 01:15
hi,
its 2 servers. we have uploaded to both servers.
Initially, we thought its a filename problem as it consist of alot of unknown characters, we changed to a simple one, it still dun work.
How do we check if "IP voice media streaming" is running when MOH stops?
Which part of the log shd we check.
Thanks alot in advance for your advises.
Avner Izhar Mon, 08/27/2007 - 07:10
In ccmadmin, go to application>call manager servisability>tools>control center. Then select servers IP address and check if the 'ip voice media streaming' is running, on both servers. That will tell if the service hangs or not.
HTH, Avner.
ONLYUNITED Mon, 08/27/2007 - 08:50
Have verified that "IP voice media streaming" is running, hence the service does not hang.
When I add default MOH files, it is working fine. 1 year ago, we add a new customised MOH file, it is working fine too. Only this time rd, when we try to add another new customised MOH file, this problem occurs.
Avner Izhar Mon, 08/27/2007 - 10:23
Yes, I see, in that case I'd go for a TAC case.
HTH, Avner.
ONLYUNITED Mon, 08/27/2007 - 23:30
Hi Avner,
Thanks for the advise so far.
Could it be the wav file problem. I have checked the format, length and etc. Format is the same and the rest looks fine.
Cheers
Avner Izhar Tue, 08/28/2007 - 07:31
Could be, haven't seen it before, but I guess it's not impossible.
You can delete it from the system and upload the original again, let the audio translator to process it again.
HTH, Avner.
