07-18-2007 07:29 PM - edited 03-03-2019 05:56 PM
hi..
anybody you there knows all about the router command or IOS can you give where a good site for those command
07-18-2007 08:06 PM
your question is very broad.
here ya go
http://www.cisco.com/en/US/tech/tk648/tsd_technology_support_category_home.html
Please rate all helpful posts
Rgds
Jorge
07-18-2007 09:13 PM
07-18-2007 09:27 PM
HI Paul,
Please refer link below:
http://www.cisco.com/univercd/home/home.htm
Based on the Version / Models you choose (in the drop-down box) the required Documentation will be listed. You can choose as per your requirement.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
07-18-2007 10:32 PM
Hi Paul,
Given below is a link that provides release notes and command reference for all cisco devices.
For router IOS selection try the tool given below:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this helps!
