WCCP Configuration on WS-C3560G
Jul 18th, 2007
Hi Team,
I would like to get some info on configuration of WCCP on WS-C3560 Switch. I have enabled WCCP and I see that the WCCP has also identified its peer, but I am unable to do a transparent proxy configuration to a Trend Micro Box which is running WCCP.
I am running the latest IOS on WS-C3560 12.2.37 SE1 and it doest support the IP WCCP x redirect out command.
Sriharshaa Prabhakar
andrew.burns Fri, 07/20/2007 - 07:40
  • Gold, 750 points or more
The "redirect out" command isn't supported on the 3560 as you've discovered - the following link covers the limitations:
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a008081db5b.html
I think the Trend only supports GRE (not L2-rewrite) but I'm fairly sure the only method currently available on the 3560 is L2-rewrite so you may be out of luck with this.
Andrew.
Sriharshaa Prabhakar Fri, 07/20/2007 - 12:06
Hi Andrew,
You are correct, the Trend Micro supports GRE, Thanks for your post, I believe I would not be able to achieve the redirection using the WS-C3560G Box...
