Can Aironet1200G which upgraded from 1200b convert to LWAP?
Jul 18th, 2007
Hi All,
My customer has some Aironet 1200G which were upgraded from Aironet 1200b (by replacing the 11b module in the back panel of the AP). So I would like to ask could these upgraded 1200 be converted to LWAP by using the Cisco Upgrade Tools? Thanks for helping!
Best Regards
Overall Rating: 5 (1 ratings)
rob.huffman Thu, 07/19/2007 - 04:18
Hi Jason,
The 1200 Series can be upgraded to LWAPP with the G Radio model listed below;
Solution Requirements
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
All 1130AG access points
All 1240 AG access points
For all IOS-based 1200 series modular access point (**1200/1220 Cisco IOS Software Upgrade, 1210 and 1230 AP) platforms, it depends on the radio:
if 802.11G, MP21G and MP31G are supported
if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
From this good doc;
Hope this helps!
pmccubbin Fri, 08/24/2007 - 05:45
Is there anyway to tell via the CLI what type of Radio is installed in an AP?
I do a show version and show hardware and all I receive are the model numbers.
All responses will be rated. Thanks!
pmccubbin Fri, 08/24/2007 - 12:07
Many thanks for the link. We saw the compliance label for radio modules (AIR-MP21G-x-K9) and still got an error message from the Cisco Upgrade tool saying the Radio wasn't supported when the documentation clearly said it was.
I'll post the results from our TAC case when we resolve it.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
