Show connected vpn users
Jul 18th, 2007
We are running Cisco IOS 12.4T on our routers and our remote users connect from their laptops via IPSec to our routers to access the resources in the internal network. How can I see a list of current connected users? What is the IOS command for it?
Overall Rating: 5 (1 ratings)
m.sir Wed, 07/18/2007 - 22:31
Try command
show aaa user all
You get output with lot of information
so you can grep only uesr info with command
show aaa user all | i IPSEC-TUNNEL: Username=
svarc1977 Wed, 01/23/2008 - 02:51
Hi all,
i have same problem. When I used show aaa user all I got "NET: Username=(n/a)". There is no information about username you can see attach. The second broblem for me is how can I check wchich ip address have been assignet to vpn client? Wel i can use show ip local pool but there is no info about vpn client. Can you help me. Thnx.
markanthony Mon, 03/10/2008 - 21:47
Has anyone figured if this is possible to see current users connected? While I'm not typically a fan of web interfaces and prefer CLI, our VPN concentrators have a great web interface that show us the logged in users and what IP they are using. Would be really handy is IOS had this as well.
dfutros Tue, 03/11/2008 - 07:07
show crypto session detail. This will give
all the detail about the client and session
fircosoft1 Wed, 01/05/2011 - 07:22
Thanks dfutros !
with IOS Version 12.4(24)T2, it works perfectly:
FIRCOPAR-RTR-1#show crypto session detail | include Username
Username: minos
Username: virgile
Username: henri
