IOS Upgrade on 1760
nkm
Just wondering if any one can clarify if the upgrade we are planning to do on our 1760 router to Cisco 1700 Advanced Security Feature Pack has support for ADSL over ISDN, from the Feature Navigator, it doesn't, however has for ADSL over PSTN.
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Generally Advanced Security feature set should support ADSL over ISDN, the following Advanced Security image supports ADSL over ISDN:
c1700-advsecurityk9-mz.123-8.XX1.bin
HTH,
Mohammed Mahmoud.
purohit_810
Level 5
Level 5
yes, mohammed is right.. follow him.
Dharmesh Puorhit
Does the same image also support ADSL over PSTN?
hi Nik,
Yes it does.
HTH,
Mohammed Mahmoud.
Thanks for that, however when I look the image up on the Feature Navigator, it only has the following
ADSL Support
ADSL over ISDN
No mention os PSTN, that why I am confused?
Does ADSL Support mean PSTN as well?
ADSL support is sometimes referred to using multiple expressions, like ADSL over PSTN and ADSL over POTS.
HTH,
Mohammed Mahmoud.
