default vlan and native vlan
Answered Question
Jul 19th, 2007
I've configured all my trunk connections to have the following:
switchport trunk native vlan 9
switchport mode trunk
All ports on my switch are trunk ports. However if I do show vlan brief I see all my ports listed in the default vlan i.e 1. Shouldn't they be in vlan 9? Can anyone explain this behaviour.
Dan
Correct Answer by Amit Singh about 9 years 6 months ago
Dan,
Just to clear up the things, a trunkport is basically a port which belongs to all the vlan. Its doesnot belong to single vlan and it will never show you the same under " show vlan " if your trunk is working properly. If your port is not an active port and a trunkport, bydefault all the ports will be in vlan 1. The trunk port which is working fine should should you it as a port of both the vlan1 and the native vlan 9.
Do " show interface trunk " on your switch and it should tell you the same.
Let us know if you have any queries.
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
dan_track Thu, 07/19/2007 - 06:19
Only two trunks ports have somehting connected into them, the remainder haven't. It's those that are showing up in vlan 1.
Dan
Correct Answer
Amit Singh Thu, 07/19/2007 - 06:28
Dan,
-amit singh
