CME configuration
Jul 19th, 2007
I have just installed a Cisco CME 4.0 systems and would like to configure the following option:
There are 5 Directors with their own extentions and one secretary. I want all the calls to go to the secretary end then she can forward them to the directors.
Any idea on how to do this?
Dean
paolo bevilacqua Thu, 07/19/2007 - 02:10
  • Hall of Fame,
    Founding Member
Which lines to the pstn do you have ?
If analog FXO, under voice port, confiugure plar opx to the sec. extension. If ISDN BRI or PRI with DID, make that the main number is sec. 's extension.
Hope this helps,please rate post if it does!
