Snmp oid for Qos
Jul 19th, 2007
I configured priority queuing on my Cisco 2800 serial interface.
Four Queues high ,medium,normal,low were assigned a queue size and mapped with an individual access list.
I would like to monitor the packet drop rate at individual Queue using by Nms software.
Could someone help me in getting the exact snmp oid value for polling the value.
Ravi
Apollo Sindhoori,
Chennai, India.
Overall Rating: 5 (1 ratings)
David Stanford Thu, 07/19/2007 - 06:34
Look at the CISCO-CLASS-BASED-QOS-MIB. Here's an example:
1) Query ifDescr to find the interaface index that has the policy
BIN/snmpwalk -c public 14.1.1.1 ifDescr
interfaces.ifTable.ifEntry.ifDescr.1 : DISPLAY STRING- (ascii): FastEthernet0/0
2) Query cbQosIfIndex to get the QOS mapping to Index BIN/snmpwalk -c public 14.1.1.1 cbQosIfIndex
cbQosIfIndex.1111 : INTEGER: 1
cbQosIfIndex 1111 is the index for ifDescr 1 FastEthernet 0/0
3) Now cbQosClassMapCfg table for the cbQosCMName name object
BIN/snmpwalk -c public 14.1.1.1 .1.3.6.1.4.1.9.9.166.1.7.1
cbQosCMName.1025 : DISPLAY STRING- (ascii): class-default
cbQosCMName.1097 : DISPLAY STRING- (ascii): Snmp
cbQosCMDesc.1025 : DISPLAY STRING- (ascii):
cbQosCMDesc.1097 : DISPLAY STRING- (ascii):
cbQosCMInfo.1025 : INTEGER: matchAny
cbQosCMInfo.1097 : INTEGER: matchAll
Now query the cbQosConfigIndex to correlate the cbQosCMName value to
our cbQosIfIndex and cbQosConfigIndex
BIN/snmpwalk -c public 14.1.1.1 .1.3.6.1.4.1.9.9.166.1.5.1.2
cbQosConfigIndex.1111.1111 : Unsigned32: 1107
cbQosConfigIndex.1111.1113 : Unsigned32: 1097
cbQosConfigIndex.1111.1117 : Unsigned32: 1105
cbQosConfigIndex.1111.1119 : Unsigned32: 1109
cbQosConfigIndex.1111.1121 : Unsigned32: 1025
cbQosConfigIndex.1111.1125 : Unsigned32: 1029
Take the values from cbQosConfigIndex and match them to values found in cbQosCMName
for the given Class-map name and this gives you the cbQosPolicyIndex, cbQosObjectsIndex
values needed to query the cbQosCMStatsTable table with for a given class-map
4) Next I know that the Index for cbQosCMStatsTable is numbers for (cbQosPolicyIndex,
cbQosObjectsIndex) 1111.1121 and 1111.1113.
Simply grep for 1113 and 1121 in my snmpwalk of the cbQosCMStatsTable to get the
stats values.
BIN/snmpwalk -c public 14.1.1.1 cbQosCMStatsEntry |grep 1113
cbQosCMPrePolicyPktOverflow.1111.1113 : Counter: 0
cbQosCMPrePolicyPkt.1111.1113 : Counter: 0
cbQosCMPrePolicyPkt64.1111.1113 : Counter64: 0
cbQosCMPrePolicyByteOverflow.1111.1113 : Counter: 0
cbQosCMPrePolicyByte.1111.1113 : Counter: 0
cbQosCMPrePolicyByte64.1111.1113 : Counter64: 0
cbQosCMPrePolicyBitRate.1111.1113 : Gauge32: 0
cbQosCMPostPolicyByteOverflow.1111.1113 : Counter: 0
cbQosCMPostPolicyByte.1111.1113 : Counter: 0
cbQosCMPostPolicyByte64.1111.1113 : Counter64: 0
cbQosCMPostPolicyBitRate.1111.1113 : Gauge32: 0
cbQosCMDropPktOverflow.1111.1113 : Counter: 0
cbQosCMDropPkt.1111.1113 : Counter: 0
cbQosCMDropPkt64.1111.1113 : Counter64: 0
cbQosCMDropByteOverflow.1111.1113 : Counter: 0
cbQosCMDropByte.1111.1113 : Counter: 0
cbQosCMDropByte64.1111.1113 : Counter64: 0
cbQosCMDropBitRate.1111.1113 : Gauge32: 0
cbQosCMNoBufDropPktOverflow.1111.1113 : Counter: 0
cbQosCMNoBufDropPkt.1111.1113 : Counter: 0
cbQosCMNoBufDropPkt64.1111.1113 : Counter64: 0
BIN/snmpwalk -c public 14.1.1.1 cbQosCMStatsEntry | grep 1121
cbQosCMPrePolicyPktOverflow.1111.1121 : Counter: 0
cbQosCMPrePolicyPkt.1111.1121 : Counter: 72016
cbQosCMPrePolicyPkt64.1111.1121 : Counter64: 72016
cbQosCMPrePolicyByteOverflow.1111.1121 : Counter: 0
cbQosCMPrePolicyByte.1111.1121 : Counter: 15904975
cbQosCMPrePolicyByte64.1111.1121 : Counter64: 15904975
cbQosCMPrePolicyBitRate.1111.1121 : Gauge32: 0
cbQosCMPostPolicyByteOverflow.1111.1121 : Counter: 0
cbQosCMPostPolicyByte.1111.1121 : Counter: 15904975
cbQosCMPostPolicyByte64.1111.1121 : Counter64: 15904975
cbQosCMPostPolicyBitRate.1111.1121 : Gauge32: 0
cbQosCMDropPktOverflow.1111.1121 : Counter: 0
cbQosCMDropPkt.1111.1121 : Counter: 0
cbQosCMDropPkt64.1111.1121 : Counter64: 0
cbQosCMDropByteOverflow.1111.1121 : Counter: 0
cbQosCMDropByte.1111.1121 : Counter: 0
cbQosCMDropByte64.1111.1121 : Counter64: 0
cbQosCMDropBitRate.1111.1121 : Gauge32: 0
cbQosCMNoBufDropPktOverflow.1111.1121 : Counter: 0
cbQosCMNoBufDropPkt.1111.1121 : Counter: 0
cbQosCMNoBufDropPkt64.1111.1121 : Counter64: 0
