07-19-2007 02:14 AM - edited 03-07-2019 12:25 AM
I have the following on my switch:
FastEthernet0/16 is down, line protocol is down (err-disabled)
Does this mean the port is disabled by the switch or by a human? How would one know when to err-disable a port? What are the commands?
If I want to enable the port again, can I and how will I go about doing it?
wvw
Solved! Go to Solution.
07-19-2007 02:33 AM
Hi, [Pls Rate if HELPS]
Port-Security Feature has been implemented in FastEthernet 0/16.
Security Violation has been done on this Port. There is a rule set with Port-Security Feature called if Security Violation is done means shutdown the Port ie., Port is disabled by the Switch.
So, someone has Violated the Security Restrictions on this Switch Port. So the Switch has disabled the usage of Port further.
You will have to Manually login to the Switch go into the Interface Configuration mode and Issue the "no shutdown" command under the FastEth0/16 Port to re-enable the Port to UP Status.
Please Refer Link below:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
#show port-security
command will show help you to identify the Problem. I hope some Mac-address, VLAN, IP-Address has been binded to this Particular port.
Some Violation on this Security Feature (on interface) will make the Interface go into Shutdown State.
You will have to Manually enter the Interface Configuration mode & input "no shut" command in config-if to re-enable the Port to UP status.
To See the Interface is in Shutdown State:
Switch#sh run interface fastEtherneto/16
Also, verify the Security Feature using "Show port-security" command output.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
07-19-2007 02:33 AM
#show port-security
PLS RATE if HELPS
Best Regards,
Guru Prasad R
