catalyst 6500 crash
Our catalyst 6500 crashed.
Would be grateful if someone tells me what the show log output below means?
pewpsw02> (enable) show log
Network Management Processor (ACTIVE NMP) Log:
Reset count: 42
Re-boot History: Jul 19 2007 11:44:12 0, Sep 11 2006 17:57:41 0
Oct 19 2005 01:02:07 0, Nov 15 2004 12:22:06 0
Jul 15 2003 17:55:22 0, May 07 2003 19:20:22 0
May 07 2003 17:33:43 0, Apr 10 2003 18:05:14 0
Apr 04 2003 21:27:28 0, Apr 03 2003 22:35:37 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 1 Power Supply 2 Failures: 2
Swapped to CLKA: 0 Swapped to CLKB: 0
Swapped to Processor 1: 0 Swapped to Processor 2: 1
DRAM Failures: 0
Exceptions: 5
Loaded NMP version: 6.3(6)
Reload same NMP version count: 15
Last software reset by user: 4/4/2003,21:26:34
NMI cause: Watchdog timer
Software version = 6.3(6)
EPC: 8074D74C
Stack content:
sp+00: 82BF9014 83FB701D 00000001 00000000
sp+10: 32303037 204A756C 20313920 31313A34
sp+20: 333A3136 20676D74 202B3032 3A303020
sp+30: 25504147 502D352D 504F5254 544F5354
sp+40: 503A506F 72742035 2F343320 6A6F696E
sp+50: 65642062 72696467 6520706F 72742035
sp+60: 2F34330D 0A000000 00000000 00000000
sp+70: 00000000 00000000 00000000 00000000
sp+80: 00000000 00000000 00000000 00000000
sp+90: 00000000 00000000 00000000 00000000
sp+A0: 00000000 00000000 00000000 00000000
sp+B0: 00000000 8075173C 3C313733 3E323030
sp+C0: 37204A75 6C203132 2031313A 35333A30
sp+D0: 3520676D 74202B30 323A3030 20255041
sp+E0: 47502D35 2D504F52 54544F53 54503A50
sp+F0: 6F727420 352F3337 206A6F69 6E650001
Register content:
Status: 3451FC25 Cause: 00000000
AT: 00000000
V0: 00000000 V1: 00000000
A0: 821BF090 A1: 00000170
A2: 55555555 A3: 83FB6B20
T0: 00100000 T1: 0000000E
T2: 00000010 T3: 34010021
T4: 0000060E T5: 00002B06
T6: 00000104 T7: 00000109
S0: 823A19D0 S1: 82420590
S2: 00000000 S3: 00000005
S4: 00000055 S5: 00000015
S6: 000000A8 S7: 817177B0
T8: 82BCBCD2 T9: 82B651F4
K0: 80005FC8 K1: 83FB6FB8
GP: 815750A0 SP: 83FB6FB8
S8: 00000001 RA: 8074D6C0
HIGH: BFC01540 LOW: 00A80000
BADVADDR: 81549015 ERR EPC: 8074D74C
EOBC Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
NVRAM log:
01. 6/20/2000,16:28:16: updateRuntimeWithNVRAM:Redundancy switch over: 2
02. 3/11/2003,09:39:59: convert_post_SAC_CiscoMIB:Block 0 converted from version 2 to 8
03. 3/11/2003,09:40:07: supVersion:Nmp version 6.4(1)
04. 3/11/2003,11:43:28: supVersion:Nmp version 6.3(9)
05. 3/19/2003,09:53:25: supVersion:Nmp version 6.4(1)
06. 3/15/2003,23:22:46: convert_post_SAC_CiscoMIB:Nvram block 0 unconvertible: 8(2)
07. 3/15/2003,23:22:46: check_block_and_log:Block 35 has been deallocated: (0xBE006B58)
08. 3/15/2003,23:22:46: check_block_and_log:Block 44 has been deallocated: (0xBE05E44C)
09. 3/15/2003,23:22:46: convert_post_SAC_CiscoMIB:Nvram block 61 unconvertible: 5(4)
10. 3/15/2003,23:22:46: convert_post_SAC_CiscoMIB:Nvram block 62 unconvertible: 4(3)
11. 3/16/2003,01:51:28: convert_post_SAC_CiscoMIB:Block 0 converted from version 2 to 8
12. 3/28/2003,22:20:17: supVersion:Nmp version 6.3(6)
Module 3 Log:
show test on all the modules say PASS.
guruprasadr Thu, 07/19/2007 - 03:28
  • Gold, 750 points or more
HI, [PLS RATE if HELPS]
Can you please post the output of "show module". If possible post the "show tech-support" output to wide-analysis.
For the ACTIVE NMP
WARNING: Power Supply 1 has failed 1 times.
WARNING: Power Supply 2 has failed 2 times.
TRY THIS: Capture the output of 'show system' and post the same.
WARNING: The Supervisor in slot 2 has changed from Active to Standby 1 times.
This may be due to redundancy failover or to the synchronization process of the
ACTIVE and STANDBY Supervisors.
TRY THIS: Ensure that the Supervisors are identical (i.e. same EARL, memory, and
uplink modules). If they are not, contact the necessary people to obtain the
correct configuration. If they are identical, the Supervisors are probably failing over. Determine if either of the Supervisors are faulty by examining the following commands while each Supervisor is active: 'show system', 'show module', 'show
test' and 'show config'.
WARNING: The log output indicates 5 exceptions.
It is a high-priority interrupt that cannot be disabled by another interrupt
operation. Fatal exceptions (which are exceptions where packets cannot be forwarded), are recorded on the NVRAM log.
TRY THIS: Reseat the Supervisor module and all the linecards. If there is a frequent
increase in the number of exceptions, open a service request with Cisco at TAC Service Request Tool.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
