winmgmt cause CPU spike
Jul 19th, 2007
Hi all,
Have anyone got problem with winmgmt.exe process in Call Manager ?
Currently I'm using CCM 4.1(3)SR4D. I know that the cause of winmgmt spiking is the monitoring software Cisco Unified Operations Manager 2.0. Currently I disable the WMI service in Call Manager, but as a result my monitoring service doesn't work. Any solution so Call Manager and monitoring software can both work without disturbing each other ? This is quite a dilemma.
Great thanks all.
Wiyandi
sr2290723 Tue, 07/24/2007 - 00:34
I have checked my servers, and the logging level is already set at "Errors only", but the problem still occurs. I'm using OS 2000.2.7.
Thanks.
Wiyandi
ybanezc Thu, 10/25/2007 - 23:05
Have you already resolve this issue because im also having same problem but for me I installed Operation manager 2.0.1.
I appreciate if you help me.
joepapesh Fri, 10/26/2007 - 05:00
We have had problems with winmgmt.exe spikes caused by CUOM, and I think we are finally over them. There are at least two bugs that could be leading to your problems...
CCM OS - as referenced above you need to upgrade your OS (via the Cisco provided upgrades, and patches) to cover for the Microsoft bug. I am now on 2000.4.4aSR10
CUOM interoperability - the bug CSCsh75491 (in new Bug Tool) specifically references CUOM causing the CPU spike. I did the work-around, and have since upgraded from 2.0.0 to 2.0.1 on CUOM to get the bug fix.
Here is a link to the CUOM bug...
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsh75491
I hope this helps,
--Joe
