1000 based port
iqbalkhan
hi
In core switch we found port support 10/100/1000 and many port only mention 1000 based. so the port which only support 1000 based they can confirure for 100 based???
thanks
biplob
guruprasadr
Level 7
Level 7
Hi,[ Pls Rate if HELPS]
What is the Model Number of your Core Switch. INFO:1000 base port will not support speed as 100
1000 Based speed ports are Gigabit Ports with Fiber Optic Interface(Port) options (no copper ports). The capability of the Port will be 1000Base-SX will support only 1000 as speed.
You will not be able to Configure the port as speed 100. If you need to have 100 as speed of the port means you may require 100Base-FX Ports in the Core Switch.
Else only Copper ports are eligible to operate in 10/100/1000 base speeds which is 100Base-T Ports.
PLS Rate if HELPS
Best Regards,
Guru Prasad R
mohammedmahmoud
Level 11
Level 11
No, 1000 based ports won't be able to run 100 based.
HTH,
Mohammed Mahmoud.
