regester value 0xf
Jul 19th, 2007
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48PS 12.2(25)SEE2 C3560-IPBASE-M
Configuration register is 0xF
these switch offen gets hanged when i was going through the document i found that i need to make the regester value to defoult i.e 0x2101 but i am not able to do that it does not go into the roman mode by ctrl+break, it does not work with mode button also please let me know what i need to do for that.
thanks.
guruprasadr Thu, 07/19/2007 - 04:17
  • Gold, 750 points or more
HI, [PLS Rate if HELPS]
1.Enter the enable mode
2.Enter the global configuration mode
3.Reset the configuration register as:
cofig-reg 0x0
4.exit
5.Reload
Follow the above steps and after the reload of the Router with the new Configuration register value it will directly enter the ROM Monitor mode.
Then, reset the configuration to original value now as:
rommon1>confreg 0x2101
rommon2>boot
By this time your Switch should have loaded to Normal Service.
Hope i am Informative.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
lalmohammad Thu, 07/19/2007 - 04:24
Guru thanks for the response, i am not able to execite the cofig-reg 0x0 commant there is no such command in this switch. what else could be done.
by holding mode button it goes in the
Switch:
but when i give the cofig-reg 0x0 command it says invalid.
mohammedmahmoud Thu, 07/19/2007 - 04:27
  • Green, 3000 points or more
Configuration register is 0xF is the normal value for the 3560 and can't be changed, i don't think that this has anything to do with the switch hangs.
HTH,
Mohammed Mahmoud.
lalmohammad Thu, 07/19/2007 - 04:40
could you help me what could be the problem.
this is the show run.
INHYDAGL-SW-04#show run
Building configuration...
Current configuration : 8618 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname INHYDAGL-SW-04
enable secret xxx
enable password cisco
username gopi secret xxx
username support secret xxx
aaa new-model
aaa session-id common
vtp mode transparent
ip subnet-zero
mls qos
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 10
name Management
vlan 11
name IT
vlan 12
name Development
vlan 13
name BPO
vlan 14
name Voice
vlan 15
name Server
vlan 16
name Wireless
vlan 17
name Wireless-Guest
interface GigabitEthernet0/1
switchport access vlan 12
switchport mode access
switchport voice vlan 14
mls qos trust cos
spanning-tree portfast
interface GigabitEthernet0/48
switchport access vlan 17
mls qos trust cos
interface GigabitEthernet0/49
description *****Connected to Core-1*****
switchport mode trunk
interface GigabitEthernet0/50
description *****Connected to Core-2*****
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
no ip address
interface Vlan10
ip address 10.138.74.135 255.255.255.192
ip classless
ip http server
radius-server source-ports 1645-1646
control-plane
line con 0
line vty 0 4
password xxx
line vty 5 15
end
please find the show version
guruprasadr Thu, 07/19/2007 - 06:54
HI, [Pls Rate if HELPS]
After reading your "show version" output i have 2 interesting information: Read the same and take necessary Actions:
WARNING: The BREAK-KEY function is enabled.
INFO: The router will interpret a press of the console terminal's BREAK-key
(or the sending of a BREAK signal) as a command, forcing the system into ROM MONITOR
mode.
TRY THIS: To disable the BREAK-KEY function, enter configuration mode and reset
the configuration register with the 'config-register' command. Set the 8th low-order
bit (from the right) of the register to a binary 1. (You'll have to convert the
final register value from binary to hexadecimal (0xABCD) for the 'config-register' command.) Then, reload the router.
WARNING: On power-up or reload, if an error occurs with it's prescribed IOS boot
method(s), this router will not boot into the fall-back (reduced) IOS image stored
on ROM (sometimes called ROM-boot or boot-strap mode)
TRY THIS: To restore the router's fall-back ROM-boot to default function, enter
configuration mode and reset the configuration register with the 'config-register' command. Set the 13th low-order bit (from the right) of the register to binary 0. (You'll have to convert the final register value from binary to hexadecimal
PLS RATE all Helpful Replies
Best Regards,
Guru Prasad R
