K9 suffix -What encryption protocols it assumes?
Answered Question
Jul 19th, 2007
I need information about encryption protokols in some products: IDS-4215-4FE-K9, CISCOSB101-K9, NFC-5.0-SW-K9,WS-C6509-E-FWM-K9 WS-SVC-IDS2-BUN-K9. They have K9 suffix, that means strong encryption, but description's of this products doesn't have any information about it.
Correct Answer by Collin Clark about 9 years 9 months ago
It uses SSH which is part of the K9 image set.
Overall Rating: 3 (2 ratings)
mattiaseriksson Thu, 07/19/2007 - 05:29
  • Bronze, 100 points or more
The k9 subsystem has support for longer keys, which means it implements 3des and 256 bit AES.
Collin Clark Thu, 07/19/2007 - 05:38
  • Purple, 4500 points or more
True, but not on all platforms. You'll want to check the feature navigator for your platform to verify 3DES and/or AES.
HTH and please rate.
ginrakh3002 Thu, 07/19/2007 - 05:39
Is this assumes for any images? Sometimes in descriptions of products with K9 subsystem have only reference that 3DES implementedn not AES, and sometimes no reference to any encryption algorithm...
Collin Clark Thu, 07/19/2007 - 05:45
Most of the ISR routers will support 3DES and AES with the K9 image. However running AES with just the routers CPU (no encryption AIM) could cause problems, depends on how much traffic the router has to encrypt.
ginrakh3002 Thu, 07/19/2007 - 05:55
But, for example IDS-4215-4FE-K9 is intrusion detection service module, so question is, why it has K9 suffix in name and in description there is no information about encryption protocols.
Correct Answer
Collin Clark Thu, 07/19/2007 - 06:15
