07-19-2007 05:22 AM - edited 03-11-2019 03:46 AM
What is a good method of monitoring traffic at the interfaces on my ASA? How would I implement the built in capture tools?
Solved! Go to Solution.
07-19-2007 05:35 AM
You could use SNMP and a collector like RRDTool or you could use ASDM if you just need a snapshot. To use the capture command, please refer to the following link for help.
http://www.computernetworkinghelp.com/content/view/40/1/
HTH and please rate.
07-19-2007 05:35 AM
07-19-2007 02:13 PM
you can also download your capture in a format usable with Ethereal by accessing the firewall with https..
ex.
https://
** Be sure you have http enabled and are allowed to connect with it from your desired interface **
Cheers,
Jay
