Connectiing 1100 AP and Wired VLANs
Jul 19th, 2007
Problem: I cannot connect to my Cisco Aironet 1100
I am trying to ping to my AP but can?t connect to it. I?ve configured my 3750 port 2/0/14 to trunk but I?m not sure if I?m missing something on my AP. the port shows Up Up.
Network:
AP-1100
|| Trunking on port 2/0/14
Cisco 3750
I have VLAN 37 on my wired network and would like to extend it to my AP. My AP has vlan 37 configured and set vlan 1 as the native vlan.
Configs for AP:
dot11 ssid WLAN
vlan 37
authentication open eap eap_methods
authentication network-eap eap_methods
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 37 mode wep mandatory
ssid WLAN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.22
encapsulation dot1Q 22
no ip route-cache
bridge-group 22
bridge-group 22 subscriber-loop-control
bridge-group 22 block-unknown-source
no bridge-group 22 source-learning
no bridge-group 22 unicast-flooding
bridge-group 22 spanning-disabled
interface Dot11Radio0.35
encapsulation dot1Q 35
no ip route-cache
bridge-group 35
bridge-group 35 subscriber-loop-control
bridge-group 35 block-unknown-source
no bridge-group 35 source-learning
no bridge-group 35 unicast-flooding
bridge-group 35 spanning-disabled
interface Dot11Radio0.36
encapsulation dot1Q 36
no ip route-cache
bridge-group 36
bridge-group 36 subscriber-loop-control
bridge-group 36 block-unknown-source
no bridge-group 36 source-learning
no bridge-group 36 unicast-flooding
bridge-group 36 spanning-disabled
interface Dot11Radio0.37
encapsulation dot1Q 37
no ip route-cache
bridge-group 37
bridge-group 37 subscriber-loop-control
bridge-group 37 block-unknown-source
no bridge-group 37 source-learning
no bridge-group 37 unicast-flooding
bridge-group 37 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.22
no ip route-cache
bridge-group 22
interface FastEthernet0.35
no ip route-cache
bridge-group 35
interface FastEthernet0.36
no ip route-cache
bridge-group 36
interface FastEthernet0.37
no ip route-cache
bridge-group 37
interface BVI1
ip address 172.31.37.3 255.255.255.0
no ip route-cache
ip default-gateway 172.31.37.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
Config for Switch:
interface FastEthernet2/0/14
switchport trunk allowed vlan 1,22,31-37
switchport mode trunk
bcolvin Thu, 07/19/2007 - 10:08
  • Bronze, 100 points or more
Try settig VLAN 37 as your native VLAN in the AP.
jkhotsyphom Thu, 07/19/2007 - 11:23
I changed the native vlan on the AP to 37 and it did not work. I was still unable to ping the AP.
bcolvin Thu, 07/19/2007 - 22:24
Can you ping any device on VLAN 37 if you configure a PC for the same IP address as the AP and plug it into the switch port can you ping it, is the PC you are using on hte same VLAN is the VLAN you are on routed to VLAN 37?
your other choice is to save the current config and rebuild the config using the web GUI to set up your VLANS if you do this step by step you will know immeadlatly where the problem is.
as always you should check the version of IOS you are running.
andrew.brazier@... Fri, 07/20/2007 - 04:33
On the AP you must have the default VLAN set to 1 and you must configure VLAN 1 on the switch. The reason is that the AP uses VLAN 1 for management traffic, no VLAN 1, no connection to the APs IP address.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
