c1700 and load balancing alone?
Jul 19th, 2007
Hey, I have a customer that wants a replacement for his Mikrotik routing system that did not play well with multiple gateways. I was looking into an affordable solution and the 1700 series router caught my eye.
This is the solution I am planning on going with and I was wondering if it could handle fail over to multiple gateways. I am new to IOS, but I assume that can be programmed into the interface with the appropriate ISO version, correct?
If I could be directed toward some documentation, that would be great! Thanks
Amit Singh Thu, 07/19/2007 - 07:04
Hello most of the 1700 series router are end-of-sale now. I would suggest you use the 1841 modular router for the same. Yes this router can handle the multiple gateways and same can be matched based on your requirement.
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_eol_notice0900aecd8044473f.html
Please see the datasheet for 1841 and what all are supported:
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016a59b.html
Please find the 1800 series router configuratiion guide:
http://www.cisco.com/en/US/products/ps5853/products_configuration_guide_book09186a008062747a.html
HTH,
-amit singh
epproach_comm Thu, 07/19/2007 - 07:51
Thanks for the reply. I need a fast and cheap alt so I will be going with a local company that do refurbs. I would like to stick to the 1700.
