ASA not allowing ipsec connection started from within network
Jul 19th, 2007
Is there a way to fix this?
regular translation creation failed for protocol 50 src inside:192.x.x.x dst outside:x.x.x.x
acomiskey Thu, 07/19/2007 - 07:33
This error typically means that NAT-T is either not supported or not enabled on the vpn client and the vpn endpoint. Nothing wrong with the ASA.
p-allen Thu, 07/19/2007 - 07:52
we are using the at&t global dialer client. Maybe NAT-T is not supported with the client. I will have to check with AT&T
