Show temperature - IOS 12.3, 3745 router
Answered Question
Jul 19th, 2007
Hi, without SNMP monitoring, can I occasionally check temperature of a router?
The scenario is that I will be deploying few routers and switches in a non-refrigerated computer room and I just would like to see whether I could check the temperature once in a while.
Correct Answer by guruprasadr about 9 years 7 months ago
HI, [ Pls Rate if HELPS ]
As a continuation of Mohammed Reply:
Execute as below in 3745: for IOS Version 12.3:
Router#show environment
--Output of Show Environment Command--
Power Supply 1 is present.
Fan status: normal
Input Voltage status: normal
DC Output Voltage status: normal
Power Supply 2 is present.
Fan status: normal
48V Power Supply 3 is not present.
48V Power Supply 4 is not present.
Board Temperature: normal.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Correct Answer by mohammedmahmoud about 9 years 7 months ago
Kindly use the "show environment" command.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (3 ratings)
Correct Answer
guruprasadr Thu, 07/19/2007 - 23:39
Fan status: normal
Fan status: normal
PLS RATE if HELPS
Best Regards,
Guru Prasad R
