07-19-2007 08:13 AM - edited 03-05-2019 05:23 PM
Hi. Please forgive my lack of knowledge regarding QoS, but I must ask for help. I am supposed to get QoS configured on 11 switches at an elementary school in our district. An engineer has been hired to set it up at the other buildings as they were part of a construction contract with new equipment. This equip. was new in December and as a result not part of this contract. The switches we have at this school are: 1 - Cat3750 - Core switch; 4 - Cat3560 - Access switches; 4 - Cat3550 switches - Access switches; 2 - Cat2950 - Access switches. The phones will obviously be plugging into PoE ports into their various switches. Here is an example of what I have on a 3560 switch so far.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos map ip-prec-dscp 0 8 16 24 32 46 48 56
mls qos
no file verify auto
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface FastEthernet0/1
description VLAN 110: IP phone
switchport access vlan 110
switchport mode access
priority-queue out
mls qos trust dscp
spanning-tree portfast
interface FastEthernet0/2
priority-queue out
mls qos trust dscp
If anyone is willing to help, God Bless You! I don't believe any of this actually shapes the traffic. All of the above config simply prepares the switches to allow/trust the traffic from the devices. Is this correct?
Any help is appreciated!
Dan
07-19-2007 12:13 PM
yes the config simply allows the switch to trust the settings sent by the device.
I would have also tuned the queue settings on the switch.
eg on 3560
mls qos
mls qos map cos-dscp 0 8 18 26 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 1 4
mls qos srr-queue output cos-map queue 3 threshold 3 2
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 1 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46 40
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26 28 30
mls qos srr-queue output dscp-map queue 2 threshold 1 32 34 36 38
mls qos srr-queue output dscp-map queue 3 threshold 3 16 18 20 22
mls qos srr-queue output dscp-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8 10
mls qos queue-set output 1 threshold 2 75 85 50 400
mls qos queue-set output 1 threshold 4 15 100 50 400
interface g1/0/1
mls qos trust dscp
queue-set 1
srr-queue bandwidth share 1 39 24 37
srr-queue bandwidth shape 5 0 0 0
priority-queue out
Narayan
07-19-2007 07:34 PM
Thanks...I will look this over. Can you explain the "mls qos srr-queue output cos-map queue x threshold x x" command. I don't quite understand these.
Thanks again.
Dan
07-24-2007 04:03 PM
On the 3560, and 3750 there are 4 different output queues. By default, traffic gets assigned the following (CoS -> Queue)
5 -> Q1
0,1 -> Q2
2,3 -> Q3
4,6,7 -> Q4
By default, the 4 Queues will share buffers equally. But with the "priority-queue out" command, Q1 becomes the priority queue and gets preferential treatment compared to the others.
This should prioritize your Voice traffic, assuming it is correctly marked with CoS 5 and/or a DSCP value between 40 and 47. Check the documentation for your VoIP PBX and phones to be sure.
What the "threshold" commands let you do is put different types of traffic in the same queue, but still allow one traffic to be more important than the other. For example:
mls qos srr-queue output cos-map queue 4 threshold 2 1
I am putting both CoS 0 and 1 in Queue #4, but 1 gets threshold 2 and 0 gets threshold 3. Threshold 1 and 2 are adjustable, Threshold 3 is not and never gets dropped unless there is no other option.
07-24-2007 04:13 PM
I will look these over! There is a lot to learn with QoS.
