Cisco VPN Dialer woes with consumer WAPS
Jul 19th, 2007
Hi All
Question, I need to buy several consumer WAP's - DSL type , that I can connect multiple users to that will then use the Cisco VPN Dialer on there laptops to connect to there offices.
Issues I have found before is that on the consumer netgear ones I tried only 1 person could use the Cisco VPN dialer, and as soon as another person who was connbected to that WAP tried it, it knocked the first person off.
Anyone come up with this issue before and found a solution? With Linsys now being owned by Cisco I would have hoped they may have got a work around but my searches on google imply now. but I hope to be proved wrong.
Scott
slewis1972 Thu, 07/19/2007 - 11:57
Default setup is to use transparent connections with IPSEC over UDP already on the Cisco VPN dialers on the users laptops and thats works fine in most situations. That is, unless you have more 1 user on a consumer router and try to connect to one of the offices CIsco routers.
Scott
janf Thu, 07/19/2007 - 12:15
Scott,
Assuming the VPN server that the Cisco VPN client's are connecting to is either a PIX or 3000 concentrator, my previous post will take care of this issue. Believe me, I went through this before and was able to resolve the issue with one simple command in our old PIX (we now use an ASA).
J
