6608 PRI ISDN Q.931 Outpulse
Jul 19th, 2007
The 66xxTracy utility doesn't appear to offer Q.931 isdn debugs similar to what we get from IOS q931 isdn degubs. I want to see the digits being handed off, and the IE information being passed to telco. I've enabled all of what seemed to be the relevant masks in the 66xxTracy tool, but I'm not seeing what I was looking for. Here are the masks I enabled:
10:34:39.120 (LINE) TraceMask value = 00000003
Where Bit0 = Call Control Statess
Bit1 = Q931
Bit2 = Q931 Msg's
Bit3 = Line Restarts
Bit4 = E&M Trunk States/Events
Bit5 = Ground Start Trunk States/Events
Bit6 = Loop Start Trunk States/Events
Bit7 = Robbed Bit Signalling Changes
(GMSG) Set Mask -> Mask<0xFF>
(CFG) Set Mask -> Mask<0x0>
(XA) Set Mask -> Mask<0x7>
10:34:39.120 SPAN: --> TraceMask value = 00000040
TraceMask bit 0x01 --> Show Frameslips
TraceMask bit 0x02 --> Show Alarm Changes
TraceMask bit 0x04 --> Show HDLC Rx Errors
TraceMask bit 0x08 --> Show HDLC Tx/Rx Msgs
TraceMask bit 0x10 --> Show FDL Errors
TraceMask bit 0x20 --> Show ANSI PRM Tx/Rx
TraceMask bit 0x40 --> Show FDL BOCs
TraceMask bit 0x80 --> Show FDL TABS Req/Resp
TraceMask bit 0x100 --> Show Raw 1-sec Stats
TraceMask bit 0x200 --> Show Rcv Signalling Changes
10:34:39.120 (Q921) --> TraceMask value = 000000ff
Where Bit0 = BackHaul Status Messages -- DL-Est Req/Cfm, DL-Rel Req/Cfm, ...
Bit1 = BackHaul Operational Messages -- Data Ind/Req
Bit2 = D-Channel Messages -- SABME, UA, DISC, RR, ...
Bit3 = Timer Events
Bit4 = Error Events
Bit5 = State Machine Events
Bit6 = Show Variables in I-Frame Received
Bit7 = Decoded PRI Q.931 Messages
Are the ccm traces the only place I will see ISDN information of this nature, or is there a way to get this info from 66xxTracy? (4.1(3)SR5B)
Thank you.
s-doyle Wed, 07/25/2007 - 07:08
ccm trace is the only place you can see ISDN information of this nature
