ATM Bandwidth Configuration Changes
Jul 19th, 2007
Good Morning,
I am currently working on upgrading the bandwidth for our WAN connections between our main site and two remote sites from UBR to CBR bandwidth on our ATM lines. The ATM lines are configured as a group of 3 T1's at the remote sites and are setup in an IMA group. I believe that the only change in configuration that will need to be made to the IMA group will be to change the UBR bandwidth qualifier to CBR and input the new bandwidth, but I wanted to verify so that I am ready for the changes.
Thanks in advance for your assistance.
Overall Rating: 5 (1 ratings)
sundar.palaniappan Thu, 07/19/2007 - 10:01
Your understanding is correct.
Under the PVC sub-mode of IMA interface change the SC to CBR and specificy the traffic shaping values.
Sundar
