Cisco Phone Not Trusted
I have been investigating issues where certain phones traffic is not passing QoS parameters across the LAN. I started walking back through the network and got all the way to the access switch where I did a "show mls qos inter fa XX" and found the following.
trust state: not trusted
trust mode: trust cos
trust enabled flag: dis
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: cisco-phone
qos mode: port-based
This port appears in "show cdp nei"
SEP0019E7290456 Fas 3/0/22 46 H P IP Phone 7Port 1
Here is the configuration on the port:
interface FastEthernet3/0/22
switchport access vlan 2
switchport mode access
switchport voice vlan 12
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
no mdix auto
spanning-tree portfast
I have been going through the switch line by line and I have not found anything that would indicate why 90% of the ports on the switch are in a not trusted state, but 10% are.
Here is the output of the "show mls qos" command
QoS is enabled
QoS ip packet dscp rewrite is enabled
Can anyone offer any assistance before I open a TAC case?
smahbub Wed, 07/25/2007 - 07:09
According to the configuration which you have provided a cisco phone is trusted because of the command " mls qos trust device cisco-phone "
shikamarunara Wed, 07/25/2007 - 07:46
The syntax of "mls qos trust device cisco-phone" refers to the packet classification the phone does for voice and the data packets it passes through for any PC connected to it. If you have LAN QOS implemented in the network, this should be one of a few commands on each switchport that a phone is connected to.
AJAZ NAWAZ Wed, 07/25/2007 - 12:06
"I have been going through the switch line by line and I have not found anything that would indicate why 90% of the ports on the switch are in a not trusted state, but 10% are.
Are all the ports that are connected to phones configured in exactly the same way and with identical configuration?
If the answer is yes there are two things you can do, or perhaps three.
1) Reset a phone to see if it makes a difference
2) Reload the switch - see if it fixes
3) If after completing the above mentioned and most obvious actions - raise a TAC case, it definately sounds like SW related defect.
By the way what version of code do you have loaded on the Cisco switch that is connected to the phones...?
I did get a resolution to this. Cisco told me to reboot the switch and it fixed it.
Unfortunately it happens again. It appears to be a degredation in the state of the ports. We are now seeing this on connections to routers, gateways, servers, and phones. This is causing a big issue because no matter what I do there is no way to get the trust state back without taking an outage on the switch during a reboot.
I am going to get a TAC case opened again and see if there are any more resolutions to this now. I have been working with my consulting group to find a published bug or a software upgrade solution, but nothing yet.
Aaron Dhiman Thu, 12/13/2007 - 09:35
Why do you have "trust cost" and "trust device"? Also, what does "sh cdp neigh" show?
joeharb Thu, 12/13/2007 - 09:38
we have mls qos trust device cisco-phone
have tried mls qos trust cos and dscp
show cdp neighbors shows the phone on port.
Aaron Dhiman Thu, 12/13/2007 - 16:44
Have you tried to configure a port in "trunk" mode? Also, what is the switch model?
MARTIN STREULE Thu, 12/13/2007 - 13:49
This turns on trust:
mls qos trust cos
This actually turns off trust if there is no IP phone (hence "conditional trust"):
This command itself never turns on trust.
There is a lot of documentation, but actually it's not really good...
Even in the newest BCMSN book there are wrong examples...
..and then there is the SW...
I know of issues with ATAs. ATAs will end up in the Voice VLAN, but are not trusted if there is the "mls qos trust device cisco-phone".
Probably this issue is also there with other phone types.
Do you have this problem only with some phone types?
joeharb Fri, 12/14/2007 - 05:53
Odd thing...take out the mls qos trust device command and now it appears to be working: The original problem was that I wasn't seeing any matches on the policy map on the I am:
Customer_Switch#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEP000D65C2DC7A Fas 0/11 128 H P Cisco SystPort 1
SEP000D65C2CFA2 Fas 0/4 170 H P Cisco SystPort 1
SEP000D65BC9575 Fas 0/5 166 H P Cisco SystPort 1
SEP000D65C2E06B Fas 0/8 131 H P Cisco SystPort 1
SEP000D65E61447 Fas 0/7 173 H P Cisco SystPort 1
SEP000D65E61449 Fas 0/10 164 H P Cisco SystPort 1
Customer_RoutFas 0/1 121 R 1760 Fas 0/0
Customer_Switch#show run
Customer_Switch#show running-config int fas 0/11
Building configuration...
Current configuration : 215 bytes
interface FastEthernet0/11
switchport trunk native vlan 210
switchport mode trunk
switchport voice vlan 192
no ip address
mls qos trust dscp
Customer_Switch#sho mls qo
Customer_Switch#sho mls qos int
Customer_Switch#sho mls qos interface fas
Customer_Switch#sho mls qos interface fastEthernet 0/11
trust state: trust dscp
trust mode: trust dscp
COS override: dis
default COS: 0
trust device: none
Service-policy output: outgoing
Class-map: Voicertp (match-all)
269381 packets, 19284602 bytes
30 second offered rate 27000 bps, drop rate 0 bps
Match: ip dscp ef
Strict Priority
Output Queue: Conversation 264
Bandwidth 384 (kbps) Burst 9600 (Bytes)
(pkts matched/bytes matched) 615/42932
(total drops/bytes drops) 0/0
Class-map: Voicesignal (match-any)
7242 packets, 398049 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp cs3
30 second rate 0 bps
Output Queue: Conversation 265
Bandwidth 70 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 30/1668
(depth/total drops/no-buffer drops) 0/0/0
