07-19-2007 05:06 PM
Hello.
I've done some digging and cannot seem to find any relevant information on Cisco Netflow, with respect to Layer3 switches.
Is it possible to obtain Netlfow data from a Layer3 Cisco switch. How about from an ASA?
Appreciate any help.
Cheers
07-20-2007 12:14 AM
Hello
NetFlow is supported on the Cisco 800, 1700, 2600, 1800, 2800, 3800, 4500, 6500, 7200, 7300, 7500, 7600, 10000, 12000, CRS-1.
Netflow is NOT supported on the: Cisco 2900, 3500, 3750.
(On Cat4000 you need a special card for netflow support).
More netflow related information you may find on the:
http://support.caligare.com/kb/7/
or
http://www.cisco.com/go/netflow
Kind regards
Jan Nejman
Caligare Co.,
07-23-2007 12:39 PM
To get the info your looking for, you will need to enable mls flows as well as netflow.
snippet from working 6509:
mls rp nde-address x.x.x.x
mls flow ip full
mls nde sender version 5
ip flow-export source Loopback1
ip flow-export version 5 peer-as
ip flow-export destination x.x.x.x %udp port%
ip flow-aggregation cache as
enabled
You also have to enable " ip route-cache flow" for each interface that you want stats from.
~Dwann
