MGCP Gateway
bvial1989
I want to connect two CallManagers via a H.323 trunk.
CM1 -> 2821 Gateway A -> 2821 Gateway B -> CM2
now, the gateways will be linked by IP on the local LAN. I am setting up MGCP in CallManager to control the gateways, but not having any luck. How can I create and endpoint seeing that the routers are simply plugging into the local LAN?
Thanks in advance,
gogasca
Level 10
Level 10
MGCP doesnt make any sense here.
MGCP protocol was not designed for this situations use simple H323 GW or ICT in CCM.
Normally with CCM you use it for VG connecting to PSTN.
