How can I view module type or model in a router using CLI?
Jul 19th, 2007
I have a 2800 series router, i need to check what type of interface module installed in my device? what command on the router to be able to view this? thanks
Overall Rating: 5 (3 ratings)
Edison Ortiz Thu, 07/19/2007 - 18:39
  • Hall of Fame,
    Founding Member
show interface should provide that information as well as show controller.
mohammedmahmoud Thu, 07/19/2007 - 22:10
  • Green, 3000 points or more
"show diag" should give you full info about the attached modules.
HTH,
Mohammed Mahmoud.
royalblues Fri, 07/20/2007 - 02:32
Sh diag would give you a detail description of the modules installed.
The ISR routers like the 2800 also support the Sh inventory command which will provide a brief description of all the modules present.
Narayan
