How to wipe startup-config and hard disks on Cache 505
Jul 19th, 2007
Have serveral CE505 that i need to elminate. Need to wipe the hard drives, all data. Does 'disk erase-all-partitions' absolutely erase all data? How do I erase the NVRAM where the startup config is store. Basically I want to wipe the device clean except for the IOS stored in flash
Syed Iftekhar Ahmed Thu, 07/19/2007 - 21:58
"disk manufacture" <- Reformat all partitions/volumes on a disk
you can use the following command to reset configuration and data on the device to factory
default:
CE#restore factory-default
Syed
