VPN Client on SUSE Linux Enterprise Desktop
Jul 19th, 2007
Just wondering if this configuration is supported. I followed the install guide, moved my pcf into my profiles dir etc. Whenever I try to connect, I just get the following error.
"Secure VPN Connection terminated locally by the Client
Reason: Failed to establish a VPN connection."
Are there any tools for Linux out there that I can use to determine what the problem is exactly? I even disable my firewall completely just to check if that was the problem. Same error.
thomas.chen Wed, 07/25/2007 - 13:42
From the Connection Entries tab, select the connection entry to use for this VPN session. For simple mode, select a connection entry from the drop-down list.
Click Connect at the top of the VPN Client window or double-click the selected connection entry. For simple mode, click the Connect button.
Respond to all user authentication prompts.
