How to attach a modem to ASA console port
Jul 19th, 2007
Hi all
My US customer need a remote access to ASA 5505 in its China branch office.Since there is no AUX port on this product,we have to attach a modem to console port.
During the test,i meet a problem when i finish the physical link between modem and ASA console using a RJ45-to-DB9 converter,the TR LED of modem doesn't light on.However,the same link is OK when i change to a Cisco router.And i can access the router EXEC mode through analog line.
Seems that the ASA console port is a bit different with Cisco router's.But i don't know what is it.
So hope someone can help.
PS: The following method of making RJ45-DB9 converter is right or not ?If not,pls tell me how to make it correctly
Cisco SERIAL (DCE/Modem/etc)
RJ45 DB9 DB25 DB9/25 Function
1 (CTS) 8 5 CTS
2 (DSR) 1 1 DCD
3 (RX+) 2 3 RX+
4 (RX-) 5 7 GND (RX-/TX-)
5 (TX-) 5 7 GND
6 (TX+) 3 2 TX+
7 (DTR) 4 20 DTR
8 (RTS) 7 4 RTS
Thanks!
Aaron
purohit_810 Fri, 07/20/2007 - 10:21
  • Silver, 250 points or more
Ideally it should work if router's console wotk , but ASA's concole doen't work because of it has pin connectivity different.
Try in Mangt port and revert me?
Dharmesh Purohit
freedream Sat, 07/21/2007 - 03:59
First,thank you,Dharmesh.
Unfortunately,my ASA 5505 doesn't have Mangt port.There are only 8 switch ports,one console and two USB port.
What can i do then?
Aaron
freedream Sun, 07/22/2007 - 03:18
Hi,Mohammed
I know this document and i check it carefully.
I'm afraid my failure is caused for the different equipments used for the test.I'm in China,i have no US modem the Cisco document refers.And my domestic modem doesn't consist of DIP switch function.
Perhaps,i'm not able to finish such a test if this is the real problem.
Anyway,thanks for your hlep.
Aaron
